0 members (),
89
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I just finished laying on the last coat of base-coat. I used a turbine HVLP. I don't particularly like the amount of orange peel in places, even though I sprayed the last two coats fairly wet. Should I try to wet sand the base-coat before spraying on the clear-coats, or wait after the clear-coat is applied? The paint is Omni PPG. Thanks, Don. | | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | Back when I was doing a lot of base/clear painting, the procedure was to spray the clear over the base without sanding if there was less than a 4-hour time span between applying the base and following up with the clear. After 4 hours, it was necessary to scuff-sand the base coat. If you've got orange peel, I'd suggest wet-sanding the orange peel areas, and scuff-sanding the whole thing. Do a very good wipedown with a tack rag to remove any sanding dust. Jerry
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Thanks Jerry, I'm going ahead and clear-coat without sanding. After fixing a few spots I certainly can see that it makes sense to not sand the base-coat if possible. Don | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | something I've done when I've had dry spots, or light orange peel in the base coat, is to lay down at least 2 heavy coats of clear, come back the next day and wet sand the clear smooth. Then go back and lay down one more even wet coat of clear.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | Thanks Keith, I think I will need to do that. | | |
