0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75506 03/26/2007 10:40 PM | Joined: Feb 2007 Posts: 4 Junior Member | | Junior Member Joined: Feb 2007 Posts: 4 | Hey fellas, I need to know where to find the casting numbers on a big block Chevy is it the same as the small block? Thanks | | |
#75507 03/27/2007 6:29 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 72 chevy 4x4, I believe the block casting numers are above the bellhousing, the heads are in the rocker arm area, hope that helps. | | |
#75508 03/27/2007 11:34 PM | Joined: Feb 2007 Posts: 4 Junior Member | | Junior Member Joined: Feb 2007 Posts: 4 | | | |
