| | | Forums66 Topics128,094 Posts1,056,487 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 25 New Guy | | New Guy Joined: Sep 2002 Posts: 25 | Put on new fuel started up run good went for a drive died. check getting lots of fuel. Figured it was float needle sticking. Took apart cleaned up put back on. Start up idles nice give throtle, back fires quits. Ordered new carb from Jim Carter Put on new carb will not even stay running. Need help. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Sounds like you have an electrical problem. Check your ignition wires, something maybe loose. Could also be a weak coil or bad gas. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Alberta is pretty far north for a 228. Do you have an American or a Canadian GMC? | | |
