| | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 13 New Guy | | New Guy Joined: Dec 2010 Posts: 13 | I am installing a pair of Langdon's Carter-Weber's in my 1950 Chevy. I need to run a wire from my 6 volt system to get power to the electric choke. Where should I tap into to get "keyed on" source to run to the chokes. Also, what guage wire should I run.
Thanks, Chris | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | What kind of oil pressure gauge you got and is it generator or alternator. Hotrod will be here shortly and tell you a great way to do it.
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Be prepared for some pretty slow choke release trying to run 6 volts to those chokes. They're designed for 12 volts, so you'll have about twice as long a release time as is intended. I like to use a mid-1970's Vega fuel pump switch in the oil pressure gauge circuit to turn the choke heater on and off. If the engine stalls during warm-up, the heater doesn't continue to release the choke. A 16 gauge wire is plenty to carry the heater current. I'd reccomend using a wire from the back of the ammeter or the voltage supply wire to the ignition switch, with a 10 or 15 amp inline fuse to provide power to the oil pressure switch. Jerry
| | | | | Joined: Dec 2010 Posts: 13 New Guy | | New Guy Joined: Dec 2010 Posts: 13 | Oil pump sender is mechanical and the car is running a generator.
I realize that the carb are designed for a 12 volt system by Langdon said that they would work fine on 6 volts. | | |
