1 members (Hotrod Lincoln), 327 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
Page 2 of 2 1 2
This would not enplane the out of alignment problem, it is the material difference.
My Blog
The only thing I can think of to cause an out of alignment with the cap is the wrong plate in the distributor. And I'm not very sure about that.
This had definitely turned out to be a mystery.
Purchasing a nice used #1112403 distributor from another member and will keep it on the shelf and at some point in the future will install. Hopefully, this will take care of the rotor alignment issue. Will also give me a chance to take a close look at the old distributor to see if I can figure out exactly what was wrong.
For now, the truck is running great with the cap twisted a little off the normal location. As long as it's running good, I'm going to leave it alone.
Thanks again,
Ron
1952 3100
Page 2 of 2 1 2
