7 members (TUTS 59, Gray_Ghost, panic, tclederman, Peggy M, MRMEROTH11, Wickedbass), 122 guests, and 0 robots.
Topics128,068
Posts1,055,880
Members48,428
Does anybody know where you can find the "part discriptions" or part name for everything listed in the "1947-1954 Factory Assembly Manual"
In particular, the bolt discriptions. it gives the "bolt number" for every bolt on the truck, but I wanna know what those numbers mean, like "###### = 1/2' X 3' coarse thread hex bolt"
You would think there would be a parts list in the back or something but I cant find anything in the book or online
thanks a bunch
-LGringo
'54 chevy 3100. In pieces now. .... I've always liked puzzles
-Gig em Aggies! Class of 2013
I hadnt thought of that, good idea but I was only able to find 1 matching number out of the many that i need. I looked in the 29-54 master cat. and the 29-57 master cat. most the bolt numbers there begin with 18 where mine start with 10.
is there a 1954 only master cat.?
-LGriong
OLTrucks
Unregistered
OLTrucks
Unregistered
No, there is a 1929-54 master parts but includes all parts 1929-1954.
How many numbers do you have? I have a few master parts in pdf I can serch in.
This is one of my favorite resources by a Stovebolter. I've posted it many times. While it does not go by part numbers, it identifies size and it's location.
http://www.laroke.com/larryk4674/2005/bbpartshp2.htm
Drew
I like this page but it does not contain the bolts i need at this time. the ones im dealing with now hold the 2 removable crossmembers in
I had them saved on my desktop but it looks like its gone now. I know the bolts started with 10, as did many of the nuts and washers, and contained the same amount of numbers as the ones listed in the master parts cat. I dont have my factory assembly manual with me now so I cant look them up again.
-LGringo
finally go the number I need, if someone could tell me how to find out wha they are I would greatly appreciante it.
I included the 2 numbers that are listed in the master parts catalog
3707661 bolt
103323 LW
120371 nut - 1/2'' 20 threads per inch
3707660 bolt
103321 lw
120369 nut - 3/8'' 24 threads per inch
106285 bolt
103321 lw
103026 nut
106285 bolt
103323 lw
-LGringo
