4 members (74cheyennesuper, Ponchogl, baldeagle, NJC), 73 guests, and 5 robots.
Topics128,014
Posts1,055,328
Members48,419
#752863 06/07/2011 11:45 PM
I need some help here. I've put a SBC 350 into my 54. I'm trying to figure out the best way to hook up the throttle linkage to my carb while keeping my pedal that goes through the floor. Has any of you fabricated something that worked? Or is there some place I can look to find a dealer that has one for this purpose?
Cushite #752949 06/08/2011 3:54 AM
Truck Shop, Brothers, and probably several other aftermarket suppliers sell a reproduction V-8 throttle linkage for TF (55-59) trucks. It should also fit the pedal configuration on a 54-55 1st series.
Fred
Lokar makes a a couple of bulletproof throttle linkage kits.
I've used three of them on engine swap projects.
mike
Squire #754841 06/15/2011 8:58 PM
Locar
Throttle
Out of a 96 Chevy pickup.
~Jim
Cushite #755015 06/16/2011 1:09 PM
Hi From england
I have a 54 with v8
I made my linkage out of 2 x 1/4" rod joints 1/4" threaded rod with a 1/4" alu
sleeve, then i just made some quick nylon bushes for carb end
works a treat
http://www.flickr.com/photos/54chevy/
if it ain't greasy it ain't diddly
Thanks Big Chevy for the 96 throttle hook-up. I actually have a pedal that's similiar to that one that came out of a 88 Chevy Van that I should be able to make brackets for. Not sure why I didn't think of that guess I was just standing to close to the project as the say to see good options lol.
