| | | Forums66 Topics128,082 Posts1,056,303 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Hi there,
I have a 54 Chevy truck 3100, with a 12 volt system and 235 inline 6 engine. I am not getting spark and trying to trouble shoot.
I have properly gapped new spark plugs, properly gapped the points, and purchased new spark plug wires.
I checked the coil and cap for resistance with a voltmeter and both show a reading.
The only thing I can think of is to replace the points/condenser or just get a new distributor.
Before I do that, I wanted to know if it matters how the coil is connected. should the Positive on the coil connect to the starter and the negative to the distributor?
I appreciate the help. Very new to working on trucks and I see the light at the end...
Carlos | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The positive goes to an ignition resister & is connected to the starter as a bypass. The neg goes to the dist. If they were reversed it would still start & run. If no resister was put in the system when it was changed to 12 volts it will burn the points in short time unless it is using a tractor coil. Remove the dist cap & turn on the switch. Take a screwdriver & touch it across the points. Take the coil wire from the center of the dist cap & set it close to part of the engine. Each time you make & break contact on the points you should get a spark from the coil wire. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Thanks for the tip. I am planning on checking the coil wire for spark...as soon as I get an extra pair of hands.
I just wanted to make sure the coil was connected properly. I will try out your suggestion on checking the center wire. | | |
