7 members (UtahYork, MickeyP, Gdads51, Cletus1950, TexasJim50, Hotrod Lincoln, baldeagle),
105
Mod | | | Forums66 Topics128,179 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | Hey, anyone know what goes in this hole on the carb? I know the carb piston moves in and out due to vacuum but I don't know what what to do with it. When I bought the engine, there was a piece of rubber stuffed in there, but it fell out. When I plug the hole, the truck won't run. I can't find pictures or explanation for this. Carb | | | | | Joined: Feb 2004 Posts: 29,869 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,869 | That's a "vacuum break" piston bore, and the hole is supposed to have a flat steel plug pressed into the stepped end of the bore. Vacuum against the piston pulls against the automatic choke spring and helps open the choke slightly as the engine starts. If it won't run with the hole plugged, turn the idle speed screw clockwise to raise the airflow past the throttle plates. Jerry
| | | | | Joined: May 2011 Posts: 3 New Guy | | New Guy Joined: May 2011 Posts: 3 | the missing peice looks like a silver convex lens you put it in the hole and hit it with a punch to lock it in place try the auto parts store in the help section they usualy have an assortment pack
| | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | Thats a car carb. Trucks with I 6 to 59 anyway all had a manual choke.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | Where can I get the plug? I don't get the "auto parts store in the help section."
Anyone help me with this? Cheers
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What Dude means by the Help section. There is a line of auto parts called Help. They supply various popular replacement parts that otherwise are hard to find. Most parts stores handle them although they only keep a small amount of the items in the store. There is a catalog with a large amount of items. Theb store can look it up for you or I have the catalog at the shop & can look it up tomorrow. I know Carquest stores have this line & I have seen them in Advance stores. It seems you could cut a disc out of a piece of metal & super glue it in there staking it around the edges.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I found part #s in the Dorman line. What is the diameter of it? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | I got a plug and it fits perfect. Unfortunately, now my tuck doesn't run as well. 8 times out of 10 it will idle fine at a stop light. The other two, I'll push in the clutch, motor will come down to idle; then out of no where, the RPM's will drop. You can hear the advance try to catch it and it quits. Touch the starter and she fires up again.
I was at a car show today and during the idling drive through the park to my spot, it would do the same thing.
All because of the plug? There is no rhyme or reason. Vacuum leak somewhere else maybe? | | | | | Joined: Apr 2005 Posts: 6 New Guy | | New Guy Joined: Apr 2005 Posts: 6 | I would think you need to re-adjust your carbs idle and mixture screws now to compensate for the extra air that you've taken away by plugging that leak. You should be able to get it back running like it was before without too much trouble, if this is all that's going on. | | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | I reset the throttle and mixture screws to no avail. It will run perfect, then the idle just falls out of it. When I pulled into my driveway the throttle pulsed and wanted to quit. I floored it and it sorted itself out.
The hard part is everything works perfect, set properly, then for now reason, the idle just crashes.
Like I said previously, its a 1 in 5 chance it happens, not consistent. | | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Hi, Lode51, one thing to check is the play in the distributor bushings. To check, set the point rubbing block on the highest part of the cam and then push with finger the cam away from the block and check clearance, then pull the cam towards block and recheck clearance and that will tell you how worn the bushings are. Maybe Hotrod will step in and say what is a usable difference is. I found this out with a 1950 ARIEL SQU. 4. When I would come to a stop it would idle between 0 and 2000 rpm. It had a point gap of .016" but I could change it by .022 with the above method. I had new bushings installed and then had normal idle speed.
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
| | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | Distributer bushings... hmm... never thought of that. I don't know why that would become an issue, the same day I put the plug in the carb. Thanks | | |
