3 members (cmayna, BC59, Wickedbass), 51 guests, and 5 robots.
Topics128,086
Posts1,056,101
Members48,434
#752092 06/05/2011 2:24 AM
question - i have a 1940 GMC 1 1/2 ton dully pickup and i'm wanting change out rearend to a later model 3.54 range and keep original 5 lug rims.anyone have an ideal of what year model or make to look for. or possibly use an adaptor to keep original rims.
1940 GMC AC 302 1 1/2-Ton Dually
BOHEMIATH
More pix in Flickr
Dumb question here... are you running the 228 or another gmc 6 like the 270 or 302? I don't think a 228 would pull the 3.54 gears well in a 1.5 ton truck.
Those 5 lug rims are about 20 inch diameter with about 35 inch diameter wheels.
Using an online calculator with 3.54 gear, a direct drive transmission, and 35 inch wheels... 65 mph looks like about 2200 rpms. A 228 would not pull that, but a 270 or 302 wouldn't have much trouble pulling those gears.
I have a 1940 3/4 ton which I have mocked up a NV4500 transmission swap. IMHO, A NV4500 would be a much better swap than an axle swap... unless you are swapping the axle because it is worn out. I chose 4.11 gears to go with my NV4500 and 302 gmc motor and 30 inch tall tires. I should be able to do 70 mph at 2350 rpm
I just read another thread that states you have a cummins and a 5 speed(NV4500?) 65mph looks like about 1612 rpm. The diesel should be able to pull that on the flat.
I don't have much experience with larger rear ends, but I remeber the 1 ton dodge diesel I got my NV4500 out of had an 8 lug 3.55 dually rear. Perhaps you can make an 8 to 5 adapter.
The 1 ton dully truck i removed the motor from had a 3.54 ratio rearend and at 65 MPH motor rpms were a little high.truck had no problem pulling what ever was put behind it.so i figured 20"rims with 34"dia. tires i would be able to trailer my 42 behind with ease. the 40 has 2 speed axel thats making a lot of noise and is geared to climb mountians.
BOHEMIATH
More pix in Flickr
If its a 40 model with the original engine, the only way it will pull a trailer with 3.54 gears and 20" wheels is down hill with a tail wind.
with cummins power- pulls up hill and down are no problem.
BOHEMIATH
More pix in Flickr
