1 members (baldeagle), 110 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#750588 05/30/2011 3:18 AM
Thinking of patching the hole in the roof of my 58 with fiberglass. LMC has a patch, but the cost is $360! Could weld in a metal patch, but thought I could duplicate the camber of the roof easier with glass. Any thoughts would be helpful.
rrenner #750624 05/30/2011 7:50 AM
Firstly welcome rrenner.
It might be an idea to make a template of your roof.
Take the template to a junk yard and try out the template against other car/truck roofs that might match the crown of your own,cut out what you need and go for it.
Personally I would prefer the repair to be in metal rather than fibreglass.
The other option as you say is a glass sunroof,the problem there is room for the slide mechanism,bearing in mind most sliding roofs retract into a void behind,there's not a lot of room in a TF roof,unless it's the lift out style sunroof glass.
More pix on Flickr.
When I want a sunroof in my truck I sit in the back.
Sorry. I just thought of that.
I would replace, or patch, a roof with metal. Or maybe you can find a new/better cab.
Dennis
Steel is the way to go for that repair. I like the junkyard idea, but remember, anything newer than about 1960 for a doner vehicle will have thinner steel. And new cars are like beer cans! A good sheetmetal shop with an english wheel or planishing hammer setup can match the curve of your roof in 16 gauge. Good luck and welcome to the Bolt! smile
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
40casey #751089 06/01/2011 3:02 AM
The 360 is the cheap way to go. A good sheet metal shop will charge that plus.
Truckrolet #751092 06/01/2011 3:07 AM
Thanks you guys, I knew I joined this forum for a reason.
rrenner #751803 06/03/2011 6:56 PM
Ter Offline
Seems to me I read of a guy using on old AD door skin for a roof patch. The doors have curves that may just work as easily as anything else.....
Good Luck
Ter
Ter #751821 06/03/2011 8:13 PM
I agree that old car roofs, trunk lids and doors make good compound curve patch panels - I used the roof off a 52 Chev sedan to fix the nose of my bus wink
