7 members (Brian Moore, tclederman, Lightholder's Dad, jupitor, treegrower, GMCJammer51, J Lucas),
223
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 50 | My truck has a 283/4speed with a Rochester 2-barrel carb. A few months ago I had the carb rebuilt by a shop in Sacramento that has a good reputation. With a little choke and fast idle it runs great. With no choke it balks when I try to accelerate. At first I thought a bad rebuild job, but it acts the same with the vacuum advance disconnected. I am leaning toward a vac adv problem. What do you guys think?
Lee Beckman | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | What you describe can be a vacuum leak, either in the carb, under the carb or somewhere else on the intake manifold or a ruptured diaphragm in the vacuum chamber. Or it can be a little trash in the main metering jet. I would eliminate the simplest first. Disconnect the vacuum line and plug it. Same for the wipers if you have vacuum wipers. How did it run before you had the carb rebuilt. | | | | | Joined: Jul 2010 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 50 | Before the carb rebuild it did not seem to balk at low end acceleration, but the butterfly valve on the carb was frozen at about 1/2 choke. When I removed the carb it had a solid gasket with only the openings for the 2 barrels. The carb factory gave me one that had some slots that looked like heat exchange stuff--could that be the problem? Lee | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Do you still have the old gasket? If so, try using it with some Permatex. Its going to be a trial and error thing, and I always try the easiest first. | | | | | Joined: Jul 2010 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 50 | Trial and error---absolutely. After trying a lot of things, eventually it turned out to be a defective old fuel filter and a carb that needed some adjustment. Now all appears to be good. Thanks
Lee | | |
