4 members (Hotrod Lincoln, Ranger, Peggy M, carbking), 44 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#751020 05/31/2011 11:43 PM
will a 1966 chevy swb frame work as a direct replacement for a 1961 swb apache frame. i would like to steer away from having to weld up new mounts. Any advice or help is greatly appreciated! Thanks. BANJOE
Banjoe #751516 06/02/2011 5:14 PM
I'm pretty shure everything bolts up exactly the same because they never eally changed much with the body except for the hood and windshield. My 1960 body has the same mounting bolts in the same places as my 65, I am pretty shure that you will have minimal to no problems with it. I am not 100% shure on it though
2007 2500HD Duramax crewcab
1965 3/4ton 4x4
1960 1/2ton 2wd
65k25 #751693 06/03/2011 5:19 AM
The '60-'62 frames are wider than the '63-'66 frames, so mounts are different and require slight modifications, in order to bolt up.
