1 members (Rusty Rod), 80 guests, and 2 robots.
Topics128,127
Posts1,056,680
Members48,452
Hi - whew, got both axles replaced with a set from a 90' blazer. Now I need to put in a new steering column. Thinking I will get one compatible with the blazer, but wondering if anyone has put new steering in a 62'? What sort of mounting advice might you give me. Is anyone interested in the original column?
Working on 62 4x4 C10 I traded for, replaced axles, now on steering column and brakes.
I just put a column out of a 87 suburban in my 62 i had to remove the safety switch and starter rods and switches, but i planned to use my old key switch to start anyway. the column is a tilt style and looks nice inside. just be sure to get the rag joint to change the shaft to double d style.
