4 members (66flea, Eisenholtz, Otto Skorzeny, Shardean), 70 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#751014 05/31/2011 11:15 PM
we have a 1961 stepside apache. we took it off a blazer 4x4 frame which i personally would not have put the truck on. our question is will a 1966 short wheel base frame be a direct replacement for the 0riginal 1961 frame. mainly no moving any frame mounts or having to weld up new mounts.we found a 66 swb frame about a mile from our house. if anyone could give advice on this we would greatly appreciate any and all help. thanks so much! BANJOE
Banjoe #751042 06/01/2011 12:53 AM
The easy answer is no. The only reason I saw that is the '61 used a torsion bar suspension. The '66 has coil springs. That aside, I'm sure the cab and box would fit on the frame without too much work. I'm not fluent in these trucks so someone my have a better/different answer than this.
Another Day In Paradise...
1964 Studebaker Daytona
1964 Studebaker Commander
Swifster #751045 06/01/2011 1:12 AM
Thanks Swifster. we actually would not mind the coils as long as the cab and box line up good with the mounting locations on the frame.
