2 members (DHedrick, WarEagle1), 103 guests, and 3 robots.
Topics128,087
Posts1,056,375
Members48,442
#75093 03/20/2007 1:37 AM
Can the axle gasket on a full floater be reused? What's the best way to seal?
If ii isn't oil soaked too bad, you could reuse it, but I would advise replacing it. I have seen some guys use RTV for the axle flange, too.
Bill Burmeister
Don't quote me on this one Skip but I think the axle flange gasket is metal on most of the full floaters I have seen. They are cheap and I personally wouldn't re-use a metal gasket, just finished rebuilding my hubs so I just went thru the same exercise. Make sure that both surfaces are good and clean and flat, i.e., no burrs. I stoned mine before re-assembling. These are hard enough to keep from leaking even when you use a new gasket.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Yes, they are metal and not hard to get so I will replace them. Thanks guys, Skip
