| | | Forums66 Topics128,087 Posts1,056,344 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#75093 03/20/2007 1:37 AM | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Can the axle gasket on a full floater be reused? What's the best way to seal? | | |
#75094 03/20/2007 1:43 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If ii isn't oil soaked too bad, you could reuse it, but I would advise replacing it. I have seen some guys use RTV for the axle flange, too.
Bill Burmeister | | |
#75095 03/20/2007 4:39 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Don't quote me on this one Skip but I think the axle flange gasket is metal on most of the full floaters I have seen. They are cheap and I personally wouldn't re-use a metal gasket, just finished rebuilding my hubs so I just went thru the same exercise. Make sure that both surfaces are good and clean and flat, i.e., no burrs. I stoned mine before re-assembling. These are hard enough to keep from leaking even when you use a new gasket. Denny Graham Sandwich, IL
Denny G Sandwich, IL
#75096 03/20/2007 6:32 AM | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | Yes, they are metal and not hard to get so I will replace them. Thanks guys, Skip | | |
