0 members (),
136
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Anyone tried to fit in a thin speaker in the overhead "console" speaker box? I'm not about to cut a hole in the ceiling as per the original aftermarket instructions for installing the speaker.
Dennis gave me a speaker box and I'm just thinking... | | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | I used the speaker (2 speakers) from Chevy Duty that were made to fit in the overhead speaker console. Works fine. I also put two more in the "boot" panels. | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | Well..there ya go..I did not know they were for sale. you are happy with the sound?
No holes needed to be cut in the inner roof?
Thanks Donsz.
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes leaf, forgot a buddy got that speaker pair for his 56 - here, it does fit Bill | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | You'll look like a boat captain with that speaker box up there.
Toot Toot
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The only hole needed will be for the wires. I found the sound to be a bit "tinny" on just the speakers in the stock location. Adding a pair of 6x9s in the cab corners, along with some fine tuning, really helped the sound quality.
Bill Burmeister | | |
