4 members (68ironhead, Wayne67vert, GRNHydra, Oswald), 131 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#750679 05/30/2011 6:01 PM
Members:
Just put on a Holley progressive 2 barrel Carb..it has an electric choke. How do I wire it?
I have room on my fuse box..but does that have power when the Ign. is turned to start ?
The fuse box ( Radio,heater,siren )is powered by my relay switch, and I have that attached to my Acc. post on my Ign. Is this ok for the choke ?
( pic of wiring) http://i1091.photobucket.com/albums/i381/snipewarrior/Wiring/P1010101.jpg
Pic of electric choke
http://i1091.photobucket.com/albums/i381/snipewarrior/Painted%20Motor/P1010106.jpg
1954 Chevy 3100 5-Window
More pix on Photobucket
"True victory is victory over one's self."
Krav Maga isn't pretty ... but it works just fine.
Jimmi V.
Jimmi_V #750692 05/30/2011 6:35 PM
The choke applies itself with a bimetal spring anytime the temperature cools down. No electric input is necessary for that to happen. The electric part comes in for releasing the choke, usually within one minute of run time in warm weather or a max of 3 minutes in sub-freezing temps. If the engine stalls with ignition or accessory voltage applied to the choke, it continues to heat and release, and makes a restart difficult. I like to run the choke release voltage through an oil pressure sensing switch, so the choke heating only happens while the engine is actually running and the switch has oil pressure applied to it.
Try using a 3-terminal oil pressure switch from a mid-1970's Chevy Vega tapped into the same oil gallery that supplies the oil pressure gauge. Connect the voltage from the fuse block you pictured to one of the normally-open terminals, with the other N.O. terminal connected to the choke. A 10 amp fuse should be plenty to operate the choke heater. Oil pressure will close those contacts and heat the choke coil while the engine is running. Either leave the normally-closed contact with nothing connected to it, or use it to ground an idiot light to supplement your oil pressure gauge.
Jeff:
please see pic to verify that I have the info. correct..I did not show the oil line going from tee on the block to oil switch. Does the oil switch come pre-plumed with an oil line?
http://i1091.photobucket.com/albums/i381/snipewarrior/Wiring/oilswitch.jpg
Jimmi V.
Jimmi_V #751377 06/02/2011 2:33 AM
Jimmi,
The oil pressure switch is threaded and screws into the T-fitting that screws into the block.
The T-fitting has one male end (into the block) and two female ends (one for the pressure switch and one for oil line to oil filter).
Here is an oil pressure switch that works on my electric chokes:
https://www.napaonline.com/Catalog/CatalogItemDetail.aspx?A=MPEOP6626SB_0213427398&An=0
Tim: Why did you use this setup vs. a wire dirict to Ign. pole on Ign. switch? Langdons says to wire dirict...Just looking at all options.
Jimmi V.
Jimmi_V #751552 06/02/2011 7:39 PM
Jimmi,
Are you asking "why" use the oil pressure switch (HrL explains that, above).
Or, are you asking about where to obtain a hot lead to run to the oil pressure switch (I did not want to run a wire from under the dash, through the firewall)?
Jimmi_V #751862 06/03/2011 11:38 PM
Langdon's is wrong- - - - -it's that simple.
Thanks Guys: I will catch power from my fuse box,run it to my
" tee'd " Oil Pressure switch. then run a wire from switch to Electric choke... Done....
Any special guage wire ?
Jimmi V.
Jimmi_V #751981 06/04/2011 2:32 PM
16 gauge ought to be plenty. It's a fairly low-current circuit. There's a nickel/chrome heater coil wound into the choke housing that provides enough heat to help the choke release itself quickly.
The first electric-heated chokes were used by Ford in the 1980's, and they ran a 16 gauge wire from the alternator stator winding to heat the choke housing. That one only produced power with the engine running, which accomplished the same result as using an oil pressure switch. It would be difficult to tap off a GM alternator that way, and just about impossible to do that with a DC generator.
Thanks Jerry
Jimmi V.
