1 members (Eisenholtz),
59
Mod | | | Forums66 Topics128,022 Posts1,055,377 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 66 | why does my 6 volt battery boil out the acid/water when i have it on a 6 volt maintainer that is at 1.5 amp I dont have the battery in the truck ,it does this over and over that now it must be all water in it I stoped charging now ,I had the caps on tight and loose and get the same thing the battery is a year and a half old | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | A continuous charge will boil out the water. Low amperage only takes longer to do it UNLESS the maintainer has a chip in it to lower the charging rate and stop it all together when the battery is fully charged. If your charger is truly a maintainer it'll shut itself off to prevent your condition. I suspect you don't have a "maintainer" but just a trickle charger that never shuts off.
| | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | A float can charge a battery but it will take some time. Float is generally designed to prevent battery from discharge. Done at a "slight" charge voltage ie 13.8 (12 V) and maybe a 0.25 amp. Current is kept low to keep both temp and evaporation ot minimum. A float of 1.5 A at 6.9 for a 6V sounds too high to me. Wont hurt anything as long as electrolyte kept at above cell top level.
Dan Bentler | | |
