5 members (tclederman, FAST55, Joe H, lumbersawyer, 1 invisible), 69 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#750135 05/27/2011 8:40 PM
why does my 6 volt battery boil out the acid/water when i have it on a 6 volt maintainer that is at 1.5 amp I dont have the battery in the truck ,it does this over and over that now it must be all water in it I stoped charging now ,I had the caps on tight and loose and get the same thing the battery is a year and a half old
Glen M #750139 05/27/2011 9:28 PM
Ex Hall Monitor
Ex Hall Monitor
A continuous charge will boil out the water. Low amperage only takes longer to do it UNLESS the maintainer has a chip in it to lower the charging rate and stop it all together when the battery is fully charged. If your charger is truly a maintainer it'll shut itself off to prevent your condition. I suspect you don't have a "maintainer" but just a trickle charger that never shuts off.
Tiny #750161 05/28/2011 12:05 AM
A float can charge a battery but it will take some time. Float is generally designed to prevent battery from discharge. Done at a "slight" charge voltage ie 13.8 (12 V) and maybe a 0.25 amp. Current is kept low to keep both temp and evaporation ot minimum. A float of 1.5 A at 6.9 for a 6V sounds too high to me. Wont hurt anything as long as electrolyte kept at above cell top level.
Dan Bentler
