1 members (Hotrod Lincoln), 92 guests, and 1 robot.
Topics128,080
Posts1,055,951
Members48,430
#749635 05/25/2011 1:17 PM
LDO
Offline
I have a 57 3100 and just purchased a V8 (tubular) crossmember from Classic so I can get rid of the front V8 motor mounts on my 283. Didn't come with any bolts so can someone tell me what size/length bolts & washer types I'll need for:
mount to block
mount to crossmember
and recommendations for crossmember to frame rails.
Thanks!
LDO #749712 05/25/2011 6:48 PM
Can you call the vendor (Classic) and ask? Other than that, go with the best (read highest yield strength) SAE Grade 8. Oh yeah, and a tape measure.
beltfed #749759 05/25/2011 10:13 PM
a grade 5 bolt will do quite well there
ron
padresag #749762 05/25/2011 10:34 PM
i use grade 8 for pretty much everything...I buy em bulk at tractor supply....for the block i'd say 3/8-16x 1" probly.... definatley want to use split ring lock washers...no clue for the rest without seeing it......dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
LDO
Offline
Thanks.
Got it all sorted out last night.
