8 members (rfs56trk, Wally / Montana, Otto Skorzeny, Hanks custodian, FAST55, HandyAndy, 3B, Donf),
53
Mod | | | Forums66 Topics128,038 Posts1,055,584 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74947 03/18/2007 12:05 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | I have most of the bugs worked out and major items like brakes ready to go on my 66 Chevy truck, but want to make sure I have all right with the engine before the maiden voyage.
The engine is a rebuilt 250 with a 1 barrel Rochester carb. I have tried setting the timing by the book with not much success. I'm assuming the marks on the tab are BTDC on the side farthest from the pavement and those closer to the ground are after.
There is no way I can get the timing to any less than 8 degrees before TDC without killing the motor. The truck seems to start best with the timing even more before TDc than that. When I get the thing where it starts really well, I get backfiring thru the carb when I hold the throttle open, but it runs ok when idling.
If I get the timing where I have the most vacuum...(around 18)the thing is really hard to start, but runs smoothe.
I have a HEI installed. Will that make some difference in the timing?
I have to wonder about the dist. being 180 out, but I didn't think it would run if that was the case. | | |
#74948 03/18/2007 1:01 AM | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | I may be wrong, but I am under the impression that the TDC mark is the one closest to the driver's side of the engine. Could that be causing your problem? | | |
#74949 03/18/2007 1:07 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Drew,
That would be how I have it interpreted. My first explanation wasn't very good! I got the timing to the range using a light, but it just seems the motor is under a little load. I don't have much vacuum with it set at this mark either.
It does start and seems to idle and rev good though. | | |
#74950 03/18/2007 2:10 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | SixPac,
I don't know what the problem is, but being a HEI should no difference in the timing, and if you were 180° out it wouldn't run!
Does a 250 with a HEI have a vacuum advance can? Are you disconnecting this and plugging the carburetor port when you time it?
Stuart | | |
#74951 03/18/2007 2:20 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Yes, has vacuum advance and plugged it. I went thru whole procedure again a little while ago...set idle, pulled vacuum line and plugged, adjusted idle mixture, set timing, reconnected vacuum..starts great, idles ok, backfires thru carb on steady throttle. Do you think I could have something wrong electronically? I also double checked the plug wires and firing order. | | |
#74952 03/18/2007 2:48 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I am not familiar with the 250, but could the harmonic balancer rubber have delaminated and the timing mark be inaccurate? One way to check the accuracy of the TDC mark is to install a stop in number one spark plug hole and rotate the engine til it hits the stop, mark the spot on the balancer, rotate the engine in the opposite direction until it hits the stop and mark the balancer at that spot. Halfway between the two marks on the balancer it TDC. | | |
#74953 03/18/2007 2:49 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Baldy,
I have heard of that happening, but the balancer is new. | | |
#74954 03/18/2007 3:26 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | SixPac,
153624....right! The backfire off idle on a steady throttle sounds like a valve issue to me.
Stuart | | |
#74955 03/18/2007 3:38 AM | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | Looks like I might be in for a lesson on adjusting valves. Never have done that, but suppose I could. | | |
#74956 03/18/2007 4:46 AM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | when you get the most vacuum, but its hard to start, just back off the timing a little, not much..that should be really close...... | | |
#74957 03/18/2007 2:45 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,m with Darin. You are just going to have to experament to get it where it works best. When it surges & runs rough at part throttle it,s usually too much advance. Try it with the vacuum advance unhooked. You may have to taylor the advance systems to suit your engine. There are some kits available for that. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
