| | | Forums66 Topics128,078 Posts1,055,940 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | I have a 1953 3600 with a title and a proper looking riveted VIN plate showing a 1953 built in Baltimore. The engine, however, has an AKCA number, indicating a 1952 manufacture.
My question: Did Chevy ever install "last year's engine" in a new truck or is this positive proof that the engine has been changed at some point in time?
Thanks for the help.
Harry | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | It could be a early 53 built in late 52. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What's the casting date by the starter? While I'm more inclined to think the engine has been replaced, as a '53 model year truck should have a '53 engine code, it could be possible that they used up any leftover '52 engines early in the model year run.
Bill Burmeister | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | I don't have all the numbers in front of me, but I know it starts with AKCA, which the book says is a 1952 code. | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | And the VIN is J53B027999. Book says they made over 40K 3600s that year, so it was not an "early" one. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | My question: Did Chevy ever install "last year's engine" in a new truck Yes, that is possible. Your stamped 216 engine serial AKCA is correct for a 3600. "NEW" models were introduced as letter I (Sept) every year.... So.... block casting date letters I, J, K, L (Sept thur Dec) would be used as the next year. Lets see if this holds true. What is your block casting date info. Something like K 3 52.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | And the VIN is J53B027999. Book says they made over 40K 3600s that year, so it was not an "early" one. What book gives model (3600, for example) production number by years? Does it have all Advance-Design years (and, production numbers by series and by each specific model, 3604 for example)? I have a few production number documents and they show the following for 3600 trucks: 1950 3600s = 66,581 1952 3600s = 38,717 1953 3600s = 40,617 | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | Thanks. I will check that in the morning and let you know. It is hard to see at night. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, that is my website. I was hoping you had found more sources. | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | The casting number is just forward of (and under) the fuel pump.
There is a GM 32 on top. Then 3835794. I think this could be correct for 52 or 53. There also is a case number on the intake manifold. It is 3835627.
Any thoughts? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | What about the number cast into the intake manifold? What is it? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3835527 is a 217 manifold from 50-53. Maybe someone else knows manifold casting codes.
3835794 is a 1952 216 block casting code.
When you ask "Any thoughts?", what kind of thoughts are you interested in?
| | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | Sorry I was not clear. I am just trying to determine if this is a possible late 1952 engine installed in a 1953 model year truck at the factory, or if the numbers indicate an engine swap. So, what do you think? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | anything is "possible" - the factory likely had a supply of engines and their parts on hand at any time to keep ahead of months of all vehicle production, might be that there wasn't a single 53 truck made with a 53 coded engine until near the end of the run - count on it being the original engine - you'd more likely have a 'swarp' if it was a newer than 53 engine code
Bill | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | I am just trying to determine if this is a possible late 1952 engine We are still waiting for you to post your block casting date. It should be on the same side as your block casting number. 3835794 Trucks 1952-53 Passenger 1952 Again, the block date code will look something like K 3 52 or B 8 53.
-Tom
| | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | Don't see any other castings. Will look again tommorow. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The casting date will be located near the starter.
Bill Burmeister | | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | Sorry - tried scraper, wire brush - saw no cast numbers near starter. Look at pix posted of where they should be. Not there.
