3 members (55shaker, 3B, 1 invisible),
144
Mod | | | Forums66 Topics128,281 Posts1,058,472 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Hey guys
I just replaced my fuel tank with a new one. When it had the old one, the fuel gauge read way past full all the time. After replacing it, it went down to empty...then I put about 20 liters of gas in, and it still reads empty. The sending unit is new too. So I figure it's the gauge itself? What could be wrong? | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Ohms. That's what could be wrong. If the Ohms rate is wrong on the new sender then it won't work. Are you using the original gauge? Your ground or hot connection was probably bad on the original sender, and that's why it didn't read correctly. You might try to test it and repair it since it probably is still better quality than the new one that you put in. These Guys probably know as much as anyone about correct senders. I bought one of their units for my 6 volt truck and it works great and was only about 50 bucks or so. | | | | | Joined: Feb 2011 Posts: 51 New Guy | | New Guy Joined: Feb 2011 Posts: 51 | I have a question on this. Is there a good way to test/troubleshoot the senders?
Mine has always read high. So I bent the float arm a little to try to adjust it, but didn't see much improvement. Is there a way to test it to see if it's bad? (I have a '64 GMC 1500) There is one place that you have not looked, and it is there - only there - that you shall find the master. | | | | | Joined: May 2011 Posts: 2 New Guy | | New Guy Joined: May 2011 Posts: 2 | have an easywire harness need trying to figure light switch which wire goes where | | | | | Joined: Jan 2010 Posts: 41 New Guy | | New Guy Joined: Jan 2010 Posts: 41 | i replaced my gauge and sender and then figured out i had a short in my sender wire... now my gauge works perfectly, except that half the time it doesnt work at all. but once in awhile it's awesome. | | | | | Joined: Oct 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 67 | seems to me if you ground the hot wire at the sending unit the gauge should read full, unhook that wire and the gauge should go to empty. | | | | | Joined: May 2009 Posts: 47 New Guy | | New Guy Joined: May 2009 Posts: 47 | check your ohm readings.My 65 was 3 ohms empty and about 37 full newer trucks from sometime in 65 they switched and the ohm reading is 0 for empty and 90 for full | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | This is kinda a dumb question, but...the fuel guage works off resistance? From where to where would I put the probes of my multimeter to get an ohm reading for this? On the sender itself or the guage somewhere?
| | | | | Joined: Oct 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 67 | i think you would disconnect the wire on the sending unit at the stud, measure from the stud to ground with ohmeter. | | | | | Joined: May 2011 Posts: 2 New Guy | | New Guy Joined: May 2011 Posts: 2 | any ideas on an e brake setup for 61 shortwide 350 700r4 original rearend thanks any ideas would be helpful happy holidays | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Is your new tank grounded? You should have a ground wire from the flange of the sending unit to the cab. Check for rust where it is screwed to the cab.
To check the sending unit, measure ohms between tne stud and ground (flange of the sending unit) while moving the float up and down.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
