1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Hello, I have a '41 GMC rolling chassis. I'm thinking of converting the Hucks to Bendex. I got everything to convert the rear. What do I need to covert the front? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | According to my 1929-51 Chevrolet Master Parts Catalog a '41-'51 front axle are the same.If this holds true for GMC, find a '51 complete axle and change it out or redrill '51 backing plates to fit your '41 axle.
Drew
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Yes. Drill the bottom bolt holes. You will need the backing plates.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Thanks for the info and the offer. What was the last year for bendex that will fit for the front?
