0 members (), 297 guests, and 6 robots.
Topics128,162
Posts1,057,042
Members48,463
so i've heard many things and I just put Points in only thing that isn't new is the condenser and i'd rather not burn out the points so heres the question. my truck is positive ground, so from the battery to the starter, the starter to the positive or negative on the coil, then to the distributer.
Josh
The supply line to the - side of coil. The + side of coil to the points (ground).
A lot of the coils in those days had double windings and will work either way. I had an uncle who worked in the shops from the thirties into the early fifties, I had my doubts but with him at my elbow I reversed the leads (trying to resolve a starting problem). It did not help the starting issue which turned out to be a loose connection on the ammeter terminals, but the coil worked the same both ways.
