0 members (),
297
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 15 New Guy | | New Guy Joined: Sep 2010 Posts: 15 | so i've heard many things and I just put Points in only thing that isn't new is the condenser and i'd rather not burn out the points so heres the question. my truck is positive ground, so from the battery to the starter, the starter to the positive or negative on the coil, then to the distributer.
Josh
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The supply line to the - side of coil. The + side of coil to the points (ground). | | | | | Joined: May 2011 Posts: 10 New Guy | | New Guy Joined: May 2011 Posts: 10 | A lot of the coils in those days had double windings and will work either way. I had an uncle who worked in the shops from the thirties into the early fifties, I had my doubts but with him at my elbow I reversed the leads (trying to resolve a starting problem). It did not help the starting issue which turned out to be a loose connection on the ammeter terminals, but the coil worked the same both ways. | | |
