3 members (Pre '68 Dave, 52Carl, Bill Marlow), 50 guests, and 2 robots.
Topics128,090
Posts1,056,028
Members48,432
#747058 05/13/2011 7:55 PM
Newbie here. I have a 1950 3100 with a '57 235 and 4-speed manual tranny. The rear end seems a little too wide for the truck as the tires extend beyond the fenders but I'm not sure if it's due to the tires or the rear end itself (sorry, no pictures available). Does anyone have the width of the correct rear end and, if so, where do I measure from?
The only info I have at this moment is:
10 bolt. 6-lug rims. Casting numbers: GM36 BI84 14055251
I have not opened the rear end to count the teeth, yet. Plan to tomorrow.
My truck is at my brother's and I'm heading there tomorrow so I can get more details as needed then.
Thanks.
Newbie
1950 Chevy 3100
If your truck has a '57 rear, it should be 62" flange to flange, according to a website I just checked. It should be close to the stock '50 in width; I'm sure someone will jump in here with correct dimensions. You did not mention what kind of rims you have... I would suspect wrong offset if they are late model 6 lugs. Let's see some pix of your truck, and good luck!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
It's saying that we need to be signed in to see your pix.
Bill Burmeister
This is the only picture I have of the rims prior to dismantling the truck and it doesn't show the rears extending beyond the fenders that well. (picture)
Newbie
1950 Chevy 3100
Looks like it's got some wide wheels on it, 8" just from what I see. That might be part of what's making it look wide. Does it have an open drive or original style torque tube?
Bill Burmeister
Open drive, outside diameter (drum to drum) is 65", drums have "fins" on them.
Newbie
1950 Chevy 3100
How are the springs attached to the housing? I have a '49 and the previous owner had the original housing but changed the pumpkin to make it an open driveline and also changed the ring and pinion, making it a mix of pre-55 post 55 rear end. For GMC the rear axle should be a H-033 (for either open or closed driveline, the pumpkin change for each case). If originally open driveline, the springs seat should be welded to the housing, if close, the seat should pivot on a bushing resting on two plates welded to the housing. I what you want is ratio, better count your teeth.
Just from the description, I'm inclined to think it might be a '77-'87 K10 rear axle. Does it have a drop out 3rd member in the front, like a 9" Ford? Or is it an integrated carrier type?
Bill Burmeister
