5 members (Gray_Ghost, BC59, 3800GUY, Peggy M, 1 invisible), 114 guests, and 2 robots.
Topics128,164
Posts1,056,965
Members48,458
I have a 48 one ton and I would like to change the gear ratio so I can drive highway speeds, any suggestions or hints?? It's an ex-ambulance with low mileage but I will be upgrading to a 261 later on. Your help is appreciated,
http://profile.imageshack.us/user/fraser88/
1 Offline
HO52/72 4.11 gearset from a 1967-1972 chevy 3/4 -1 ton, auto trans will get you to 65 MPH.
The most common fix is to install the "pumplin" from a 1967 to 72 3/4 Ton truck with an automatic. They had a ratio of 4:10. I did this swap and I can drive at 60 mph with no problem. I also have tall 16" tires on mine. Here is a writeup on the procedure:
Old GMC.com Site Article
1951 1 Ton Completed
Thanks for your help, I'll track down a 67 to 72,,,
