7 members (Samantha, cmayna, 55shaker, Bill Hanlon, TooMany2count, 1955 1 Series, Otto Skorzeny),
102
Mod | | | Forums66 Topics128,071 Posts1,055,901 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 53 | Does anybody know where you can find the "part discriptions" or part name for everything listed in the "1947-1954 Factory Assembly Manual"
In particular, the bolt discriptions. it gives the "bolt number" for every bolt on the truck, but I wanna know what those numbers mean, like "###### = 1/2' X 3' coarse thread hex bolt"
You would think there would be a parts list in the back or something but I cant find anything in the book or online
thanks a bunch
-LGringo
'54 chevy 3100. In pieces now. .... I've always liked puzzles -Gig em Aggies! Class of 2013
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | | | | Joined: Apr 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 53 | I hadnt thought of that, good idea but I was only able to find 1 matching number out of the many that i need. I looked in the 29-54 master cat. and the 29-57 master cat. most the bolt numbers there begin with 18 where mine start with 10.
is there a 1954 only master cat.?
-LGriong
| | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | No, there is a 1929-54 master parts but includes all parts 1929-1954. How many numbers do you have? I have a few master parts in pdf I can serch in. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | This is one of my favorite resources by a Stovebolter. I've posted it many times. While it does not go by part numbers, it identifies size and it's location. http://www.laroke.com/larryk4674/2005/bbpartshp2.htm
Drew
| | | | | Joined: Apr 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 53 | I like this page but it does not contain the bolts i need at this time. the ones im dealing with now hold the 2 removable crossmembers in No, there is a 1929-54 master parts but includes all parts 1929-1954. How many numbers do you have? I have a few master parts in pdf I can serch in. I had them saved on my desktop but it looks like its gone now. I know the bolts started with 10, as did many of the nuts and washers, and contained the same amount of numbers as the ones listed in the master parts cat. I dont have my factory assembly manual with me now so I cant look them up again. -LGringo
| | | | | Joined: Apr 2010 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 53 | No, there is a 1929-54 master parts but includes all parts 1929-1954. How many numbers do you have? I have a few master parts in pdf I can serch in. I had them saved on my desktop but it looks like its gone now. I know the bolts started with 10, as did many of the nuts and washers, and contained the same amount of numbers as the ones listed in the master parts cat. I dont have my factory assembly manual with me now so I cant look them up again. finally go the number I need, if someone could tell me how to find out wha they are I would greatly appreciante it. I included the 2 numbers that are listed in the master parts catalog 3707661 bolt 103323 LW 120371 nut - 1/2'' 20 threads per inch 3707660 bolt 103321 lw 120369 nut - 3/8'' 24 threads per inch 106285 bolt 103321 lw 103026 nut 106285 bolt 103323 lw -LGringo
