9 members (66flea, Rosco, Dakota Bob, 1955 1 Series, Shaffer's1950, dt235sd, Otto Skorzeny, KEVINSKI, 1 invisible),
195
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,291 Posts1,058,588 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74702 03/12/2007 3:43 AM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | 1951 3100 all orginal....What kind of rear end do I have? | | |
#74703 03/12/2007 4:23 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | One with a torque tube, made by GM. It does not have a common name like a Dana 40 or a ford 9" or a Rockwell, or a GM 10 bolt..... It's just a 51 1/2 ton rear as far as I know. Grigg | | |
#74704 03/12/2007 4:26 AM | Joined: Nov 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 108 | Thanks I am going to buy gears for the rear end...and was trying to figure out what I had...everybody suggested 3:55 | | |
#74705 03/12/2007 12:23 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | As far as I know you have only a few places to buy gears for your truck. Try Patrick's, and the usual parts catalogs like Jim Carter's and Chevy Duty, or whoever they are now. | | |
#74706 03/12/2007 1:03 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | You have a 4.11 rear rear end. The 3.55 conversion kits all come from Patrick\'s Antique Cars & Trucks . It is a a good idea to also buy the Ring & Pinion and the Ring & Pinion Installation Kit. The kit has all the bearings, bushings, clips, and gaskets that you really should replace. If you do not have a runout gauge available, Harbor Freight not has a dial indicator and magnetic gauge holder on sale. Page 15 of the Tool Disposal Notice catalog - good until 26 March | | |
#74707 03/13/2007 12:33 AM | Joined: Jul 2006 Posts: 482 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 482 | I talked with a guy at Patrick's one time. Unlike any other supplier, he knew what he was talking about. They don't make gears for my truck but if they did, I'd buy from Patrick's. | | |
