1 members (carbking),
77
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 6 New Guy | | New Guy Joined: Apr 2011 Posts: 6 | OK, I just got a flywheel and torus for an early (55-59) Hydramatic. The guy I got it from swears he unbolted it right off the back of a 265 Chevy V8. But it will not bolt up to any Chevy small block crank I have. It has a smaller center hole and the bolt pattern diameter for mounting it is smaller also. It has 6 bolt holes and 3 dowel pin holes. Any one know if there ever was a small block v8 with a different pattern? | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Any casting numbers on the flywheel or torus ?
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy LJS, that sounds like a six cylinder flywheel to me. | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | Nope, gotta call BS on that claim. The small block V-8 crankshaft flange bolt pattern didn't change for 30-something years, until they went to the 1-piece rear main seal. That 6-hole, 3-dowel arrangement is a 6-cylinder bolt pattern. Jerry
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1955-1959 6 cylinder flywheel and 168 teeth ring gear: 8615574
1955-1959 8 cylinder flywheel and 168 teeth ring gear: 8617327
| | | | | Joined: Apr 2011 Posts: 6 New Guy | | New Guy Joined: Apr 2011 Posts: 6 | OK, that's what I thought. I guess I'm still looking for a V8 flywheel. ****WANTED: V8 CHEVY TO EARLY HYDRAMATIC FLYWHEEL****** | | | | | Joined: Apr 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 36 | they are available so keep looking. the flywheel you do have is trading material, I would look for a flywheel from some of the tranny rebuilde supply places like fatsco or northern. they can direct you | | |
