1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#745912 05/09/2011 5:32 PM
well i just got my new truck home last night. she runs good. had to put a new radiator in before bringing it home. I was it had a 292 in it. but the engine suports are straight across from each other. the fuel pump is up front on the passenger side by the distributor and the side covers are only about 4 inches tall.
when i went to get it I had a new radiator but it ended up being to big. I was able to modify stuff and got it in and it did fine.
the engine casing is 3921968
with GM under it
53 or 58 under that.
so its a 230 or 250
now right behind the dipstick is the number: B89
to the left of the dipstick is: CON 2
the flat plate by the distributor the number is: CE912902
If anybody knows what it is please let me know.
thanks mark
http://i942.photobucket.com/albums/ad263/bluecarpenter/IMG_20110509_105933.jpg
bluecarpenter #746066 05/10/2011 3:19 AM
The Engine Casting number researches to both a 230 or a 250.
The Engine Code by the Distributor doesn't make any sense to me. It should be a letter, some numbers and then 2 or 3 more letters.
The B89 sounds like the Date Code (February 8, 1969).
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
