7 members (msmall, Otto Skorzeny, Phak1, 55shaker, TUTS 59, Wayne67vert, 1 invisible), 106 guests, and 2 robots.
Topics128,095
Posts1,056,069
Members48,433
#744191 05/02/2011 10:43 PM
My 51 Chev 3100 has two bolt holes in the exterior of each rear fender right above the rear wheels. Have seen trucks of the same vintage with a fender brace/support in that area that runs up to the top of the fender and I suppose that bolts to the bed.
Anyone have a source for those parts?
Tex Chev 51
Poor illustration, but I think this is what you are looking for.
http://secure.oldchevytrucks.com/FE...D-TYPE-AS-ORIG-2-SAME/productinfo/MS192/
Drew
TexChev.
The two holes were in fact for rivets.
I've heard many folks who radically lower their trucks remove these braces altogether,fill the holes and run without them.
I'm not sure what effect that would have over the long run.
Chevrolet obviously put them there for a reason.
You could try putting a wanted ad in the swap meet.
More pix on Flickr.
Guys thanks. I believe jockbolter50 called the part correctly as it bolts or rivits in the upper part of the fender rather than the lower rear.
Can't find that part listed as a center brace, but the swap meet is a probablility where I could find them.
Thanks again.
TexChev.
What side you looking for. I am not sure if both sides are the same. I may have what you need. Send me a PM
Dennis
Looked at mine tonight and I don't think they are handed.
More pix on Flickr.
