0 members (),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | In reassembling my cover to my shifter I thought this screw with left handed threads was the correct one... It does not seem to want to thread in... Is this the correct screw or is it a right handed thread ? Screw size is # 10 x 32 ... Thanks in advance...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
| | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Found the screw in the 1929 - 1954 Chevrolet MASTER PARTS and ACCESSORIES CATALOG Sec. 4.018 listed as 54 COMM w/A.T. Screw upper supt control (1/4 - 28 x 5/8) part # 439983
| | | | | Joined: Jun 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 145 | I'll have to have a look at mine,does your have a needle to show what range toy have selected behind the cover? | | | | | Joined: Sep 2009 Posts: 433 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 433 | Hydra1/2ton yes it has a needle that shows the range... I am still not sure if it is left or right handed threads... I seem to remember it being left handed threads... I am referring to the this cover ... Thanks for your help...
| | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | I don't think any of the screws were left hand thread. The shift housing is the same as a car with powerglide trans in similar years. The indicator and the detent plate on the column under the hood are the obvious differences. | | |
