5 members (frogfarmer, Charles in CA, Joe H, dt235sd, 1 invisible), 61 guests, and 3 robots.
Topics128,074
Posts1,055,910
Members48,429
#740402 04/18/2011 10:11 PM
Does anybody know what hose it takes for the upper radiator hose in a 66 with a 327. I have the one I took off but all of my parts stores can not match it with anything and want to sell me a flex hose. Any help would be appreciated. Thanks
rodwst #740414 04/18/2011 10:45 PM
Riding in the Passing Lane
I can look it up tomorrow.
George
1972 Chevy c10 Cheyenne Super
Hey rodwst. You have a PM, regarding the factory-correct upper radiator hard pipe assembly.
The book shows like 456 says. It has a metal tube with sections of 1 1/2 in. hoses.
I found a hose off of a 91 chevy that is close not sure what number it is my paper work is in the garagae, but I was looking online and came accross Bowtie Restoration Parts part number RH22 shows reproduction Hose, not really sure but it looks like it might be right though. I am just trying to stay clear of the flex hose if I can. Thanks for help
rodwst #741172 04/21/2011 4:33 AM
rodwst #742921 04/27/2011 5:40 PM
Y
yar Offline
Y Offline
Rodwst, that picture from 4-5-6 suggests a simple solution. Make a pipe out of pvc tubing in the shape you need then take that to a muffler shop with a tubing bender and have the pvc pipe duplicated in exhaust tubing of the correct diameter. If there is a metal supply store near you you could buy thicker wall tubing that would last longer. A tubing bender in good condition can bend 1/8" wall thickness tubing no sweat.
Ray
yar #743063 04/28/2011 3:22 AM
We fabricate and sell the kit. It is a reproduction of the factory-correct upper radiator hard-pipe assembly.
Did all of them come with the hard-pipe assembly, or was that a heavy-duty equipment option?
And what years was that available?
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
Brad54 #743910 05/01/2011 7:42 PM
I believe all of the V8-equipped, light-duty Chevy trucks from '63-'66 had this arrangement.
