2 members (baldeagle, 78buckshot), 79 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#7432 04/29/2003 7:45 PM
As I'm trying to clean the years of grease and grime from the leaky brake cylinders and other fluids. What cleaners, rags, steel wool, etc. have you found to work the best. Granted I don't have the bead and sandblasters so we are talking budget cleaners.
#7433 04/29/2003 8:24 PM
I start off with paint thinner and finish with simple green.
54 3100 with 235
62 flatbed dump C60 with 261
#7434 04/29/2003 8:57 PM
Don't clean those leaky brake cylinders. Toss them out and replace them with new ones. Much safer....
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#7435 04/29/2003 9:27 PM
Household "Dawn" cuts grease.
You can clean the engine grease and the cooking kettle grin all with one product.
Check out this story from a 1998 Newspaper:
* Along I-74 near Cincinnati where an overturned tanker truck spilled 20,000 gallons of animal fat on the pavement, NOTHING could get up the 2-inch-thick layer of congealed waste until Cincinnati-based Procoer & Gamble Co., came through by donating 3 tons of Dawn, the grease-fighting dish-washing liquid. "This was by far our most extreme case of grease buildup," said a company spokesman.
Joe - (Buckeye Bowtie)
"Remember it takes about 2850 bolts to built a Chevy Truck and only 1 NUT to scatter them all over the highway"
1950 3100
1971 C-10
1939 Buick Century
#7436 04/29/2003 10:36 PM
i mix a strong dose of tide and hot water together, then let the parts sit anywhere from overnight to 2 weeks, then i rinse with water.
Yes, officer it's licensed.
#7437 04/29/2003 10:44 PM
I've used EasyOff oven cleaner with good results on the grease/grime on the engine. Spray it on, let it sit for an hour or so and spray it off with the hose (spray attachment on Jet setting).
MbOutdoors (Lorne)
1952 Chev 1300
#7438 04/30/2003 4:29 AM
Anonymous
Unregistered
Anonymous
Unregistered
Or you could drive that baby over to my place and we could play with the 3000 psi steam cleaner. grin Just don't look into the chimney when you pull the trigger like Rugo did, people look a lot different without eyebrows eek :p
#7439 04/30/2003 3:01 PM
We've had excellent results with a product from POR 15. It's called Marine Clean--we just dilute it a little and use a paint brush or stiff brush to agitate the crud. Also kind to the environment. It made a believer out of my non-believing, college educated, civil engineer son--and he knows everything. grin
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
#7440 05/01/2003 7:55 PM
V
V Offline
Just remember to fully rinse then with alcohol or brake cleaner when you're done or the rubber seals
will fail from petrochemical cleaner residue .
I just put a drain pan under neath and wet it down with Gunk engine de-greaser , work it 'round with a stiff bristle bush (solvent brush) and then rise off with aerosol brake cleaner .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
