| | | Forums66 Topics128,017 Posts1,055,338 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 59 | As I'm trying to clean the years of grease and grime from the leaky brake cylinders and other fluids. What cleaners, rags, steel wool, etc. have you found to work the best. Granted I don't have the bead and sandblasters so we are talking budget cleaners. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I start off with paint thinner and finish with simple green.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Don't clean those leaky brake cylinders. Toss them out and replace them with new ones. Much safer....
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
| | | | | Joined: Apr 2003 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 66 | Household "Dawn" cuts grease. You can clean the engine grease and the cooking kettle  all with one product. Check out this story from a 1998 Newspaper: * Along I-74 near Cincinnati where an overturned tanker truck spilled 20,000 gallons of animal fat on the pavement, NOTHING could get up the 2-inch-thick layer of congealed waste until Cincinnati-based Procoer & Gamble Co., came through by donating 3 tons of Dawn, the grease-fighting dish-washing liquid. "This was by far our most extreme case of grease buildup," said a company spokesman.
Joe - (Buckeye Bowtie) "Remember it takes about 2850 bolts to built a Chevy Truck and only 1 NUT to scatter them all over the highway"
1950 3100 1971 C-10 1939 Buick Century
#7436 04/29/2003 10:36 PM | Joined: Oct 2001 Posts: 54 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 54 | i mix a strong dose of tide and hot water together, then let the parts sit anywhere from overnight to 2 weeks, then i rinse with water.
Yes, officer it's licensed.
#7437 04/29/2003 10:44 PM | Joined: May 2002 Posts: 32 Member | | Member Joined: May 2002 Posts: 32 | I've used EasyOff oven cleaner with good results on the grease/grime on the engine. Spray it on, let it sit for an hour or so and spray it off with the hose (spray attachment on Jet setting).
MbOutdoors (Lorne) 1952 Chev 1300
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Or you could drive that baby over to my place and we could play with the 3000 psi steam cleaner.  Just don't look into the chimney when you pull the trigger like Rugo did, people look a lot different without eyebrows  :p | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | We've had excellent results with a product from POR 15. It's called Marine Clean--we just dilute it a little and use a paint brush or stiff brush to agitate the crud. Also kind to the environment. It made a believer out of my non-believing, college educated, civil engineer son--and he knows everything.  | | | | | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Just remember to fully rinse then with alcohol or brake cleaner when you're done or the rubber seals will fail from petrochemical cleaner residue .
I just put a drain pan under neath and wet it down with Gunk engine de-greaser , work it 'round with a stiff bristle bush (solvent brush) and then rise off with aerosol brake cleaner .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
