0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74272 03/05/2007 9:09 AM | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | My six cylinder is locked up tighter than..... well you know..... I am trying to remove the bellhousing. Engine is out but I can't turn the flywheel enough to remove the clutch housing bolts so then I tried taking the 4 bellhousing bolts out....top two,of course were easy but the inside ones won't back out as they hit the wheel. I am left with the conclusion that I can't remove the bellhousing from the block unless I pull the pan and start pulling the bottom end apart. Am I right or is there a hope? Thanks Ralph | | |
#74273 03/05/2007 4:26 PM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy rasman57, You have to remove the clutch to get to the flywheel bolts, the flywheel must come off to get to all the bellhousing bolts. So if you absolutely can't turn the engine you have to do as you suggested and remove the pan and take the crank out from the bottom, hope that helps. | | |
#74274 03/05/2007 6:38 PM | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | If your plan is to use this engine, then you'll eventually have to pull the pan, crank, etc. so why not just bite the bullet and do it now? But, if you just need the bellhousing off, how about backing the inside bolts out until they hit the flywheel, then cut them off with a cut-off wheel (leaving enough to get some channel-locks on the stud) then back them out again until they hit the flywheel, cut them again, etc. Voila! Bellhousing is off! | | |
#74275 03/06/2007 5:00 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | You may be able to ge two out that way, but I'll bet you can't get the other two. Another way to get the engine to turn over is to remove the head, spray the cylinder walls with Kroil or PB Blaster several days in a row and hit the pistons with a large diameter log and sledge to break it loose. | | |
#74276 03/06/2007 5:25 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I wonder how you would get all six connecting rod caps off if you can't turn the crank. I'll cast my vote with Baldy. It will eventually loosen up and rotate with enough penetrant and leverage.
Stuart | | |
#74277 03/09/2007 2:27 AM | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | Well I started pullin it apart, and was lucky to get all the connecting rod caps off as well as the mains. What has be scratchin my bald head now is the harmonic balancer. Service Manual shows a couple different tools but both are the center bolt leverage against two screwed in bolts. The front of my balancer has two holes but they are not threaded..... what gives? I must be missing something here? | | |
#74278 03/09/2007 3:56 AM | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | Okay never mind....The bottom of the hole was packed with clay and harder than rock. I poked in there with a very sharp small punch and discovered threads in the back of the balancer...Wow. | | |
#74279 03/11/2007 6:36 AM | Joined: Oct 2005 Posts: 7 Junior Member | | Junior Member Joined: Oct 2005 Posts: 7 | Can you not reach in the bellhousing to loosen the clutch bolts, then the flywheel, then the bell housing bolts?
Just my Thoughts, Walt
