4 members (elhippie64, baldeagle, Phak1, 1 invisible), 51 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,420
#742561 04/26/2011 4:21 AM
With so much written on setting pinion angle it all becomes a little confusing. I'm using a digital level my trans output shaft is at -3.5 deg depending on where I set the pinion the drive shaft will see a - 2- 2.75 deg I have read that the u-joints need 1-3 deg for optimum performance. Do I want + 3.5 at the pinion? Thoughts and suggestions appreciated. Thanks G
Gmans 46 #742567 04/26/2011 4:45 AM
Pinion should be parallel to transmission in your example.
Check the driveline tech tip for more details if you want.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #742568 04/26/2011 4:57 AM
Thanks Grigg, I found the tech tip just after the post, hmmm should have looked there first.
Gmans 46 #742573 04/26/2011 6:00 AM
Make sure you don't confuse the angle with the plane. The closer you can get to the same angle, the better. However, you have to have some offset in the plane. If not, the needles will stay in the same place and wear into the cross.
crenwelge #742599 04/26/2011 1:45 PM
Ok, can you explain in detail? The horizontal plane? I hope to put this task behind me this weekend. I have enough of the truck together to do this. Thanks G
Gmans 46 #742606 04/26/2011 2:05 PM
You can see the current stance of the truck by clicking on build it has roughly a 1 1/2 deg rake overall. Thanks G
Gmans 46 #742620 04/26/2011 3:23 PM
Originally Posted by Gmans 46
Ok, can you explain in detail? The horizontal plane? ...
You're all set, review your previous notes
....my trans output shaft is at -3.5 deg depending on where I set the pinion the drive shaft will see a - 2- 2.75 deg ...
Compare to the 3 basic rules found in the Tech Tip
•Rule #1 -- Universal joint operating angles at each end of a driveshaft should always be at least 1 degree.
•Rule #2 -- Universal joint operating angles on each end of a driveshaft should always be equal within 1 degree of each other.
•Rule #3 -- For virtual vibration free performance, universal joint operation angles should not exceed 3 degrees. If they do, make sure they don't exceed the maximum recommended angles.
If the driveshaft will see 2-2.75* that's more than 1* (rule #1) and less than 3* (rule #3)
Now set your pinion centerline to be parallel with the transmission/engine, or at least within 1* (rule #2)
Again, if you need more details, pictures/drawings, or further explanation check out the Spicer manuals found in the Tech Tip
http://www.stovebolt.com/techtips/driveline/setup/index.html
Grigg
---All pictures---
