| | | Forums66 Topics128,052 Posts1,055,717 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | A question came up as to why you need a carb insulator plate on a 1955 235 engine. Is the thickness of the insulator plate an important factor or is it only to help on vapor lock or maybe air/fuel mixture?
Any information will be greatly appreciated. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy buckaroo01,the insulator is there to prevent the carb from becoming too hot from heat that would be transfered to it from the intake/exhaust manifold if it were not there. The heat in the carb would start to heat the fuel and cause it to evaporate more quickly, possibly causing a fuel starvation problem, hope that helps. | | |
