| | | Forums66 Topics128,147 Posts1,056,797 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 48 | I had a bit of an adventure today. I have read this forum enough to know that finding the front wheel bearings on a 1949 6400 can be a challenge. So....did I have an extra set ready? No....Did I have the part numbers ready for my parts guy? No....Did I even bother to check the front bearing and repack them after I bought the truck? No....Ok, I'm an idiot. haha. Anyway, to make a long story short, the outer front bearing died while a friend was driving my truck. He limped it back to my shop and I tried to find a replacement outer bearing with no luck. I had to make something work because I had a four thousand dollar two post lift in the back of the truck and the truck is too long to park inside my shop. What to do? I removed what was left of the old bearing. Basically just the inner and outer race was left. I went to O'Reilly and started going through bearings trying to find something that was at least the same size on the outer race. I found that a National a-17 had almost the same size outer race, but the inner diameter of the inner race was way to big. I then happened to place my old inner race into the inner race of the new bearing. It fit perfect! So...With a idea in my head, I went back to my shop. For the life of me I could not find my dial calipers. I guess the new bearing outer race was about .020 over sized compared to my original bearing. With my 3.5 inch angle grinder I carefully ground down the outside of the outer race and then drove it into the truck's hub assembly. I cleaned and repacked the old inner bearing and packed the new outer bearing. I assembled it on the truck, the hub was loose on the spindle because the new outer bearing was too large for the spindle. I then slid on the old inner race and everything tightened up perfectly. I tightened the spindle nut until the in and out movement of the hub disappeared. I put the tire back on and went for a test drive. The truck drove......perfect! Now, before everyone jumps in about this being unsafe. I considered that before putting this together. Other than the inner bearing exploding I do not see how it would be possible for the wheel to come off the truck. I also plan to get the correct bearing as soon as possible. But.....if someone is in the middle of nowhere and facing a BIG tow bill with a problem like mine you might want to try this little trick. I had about ten dollars and two hours getting my truck back on the road. | | |
