5 members (TooMany2count, Otto Skorzeny, MickeyP, Wally / Montana, Bill Hanlon), 101 guests, and 2 robots.
Topics128,052
Posts1,055,729
#741651 04/22/2011 8:37 PM
Im about to buy a 1995 camero front end to install in a 1954 chevy truck... Will the 95 camero work well for the install or is mostly all the camero sub frames the same? Is there any issues i may run into?
1955.1 Chevy 3600 NAPCO Truck
1957 Chevy 6400 US FOREST SERVICE
Here's a long list of all my STUFF!
The '82-'02 Camaro uses a strut type suspension, which mounts some of the suspension components (Struts, and upper control arms) to the body, rather than the frame. You will not want to use that subframe for a clipping an older vehicle. The one you want will be the '70-'81 Camaro, Firebird/Trans-Am, or '75-'78 Nova/Apollo/Ventura/Omega. The '67-'69 Camaro/Firebird and '68-'74 Nova subframe will work as well, but is slightly narrower than the later one.
Bill Burmeister
Thanks for the help!
