0 members (),
136
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | 1955.2 Chevy truck with aftermarket updated wiring harness and an owner that is just learning electrical stuff. I'm wiring up my Old Air A/C system and there are two wires that need "key on" power. One says just connect to "key on" power and the other says to hook it up to a "spotlight key on" power at the insulated fuse box. What in the world do they mean by "spotlight"? Can I just splice these two wires together and run them off one of the ACC connectors on the fuse panel? Or do I need to find two separate fuse box connections for each wire? Or can I use the wire that is labeled "electric fan" from the fuse box as I am not currently or planning on using it for an electric fan? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I would be asking the Old Air techs these questions. | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | So what are the loads served by the electrical??
Dan Bentler | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I found the A/C wires in some of the accessory bundles so I used those. I could barely read A/C and A/C fan on the two wires. The fan goes on and nothing melted so everything is A OK.
It seems like I always have a question after hours or while I'm at work where I can't call a tech line... so thats why I throw it out to you guys.
Seems like I'm the only one with an Old Air Products A/C unit. Anyone have one installed? I think the Vintage Air would have been easier to install, but got this one at a discount through BrothersTrucks.com.
