| | | Forums66 Topics128,096 Posts1,056,482 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | I have tried over and over to install the locking strips on the rear windows of my 49 5 window. I bought the installation tool from jim carter. I just can't figure out how to use it. Any Help would be appreciated. Terry
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | First you have to use alot of dish soap I mix some in a plastic cup about 1/3 soap to water and I use a paint brush about 1 inch wide to keep the rubber wet.
Than take the rubber locking strip and slide it into the tool,handle should be at the short end of the strip so you can push down and push thru the rubber at the same time, make sure it's the right side out,wet down the bottom of the window rubber, push the tool down into the rubber and turn it up and down untill the lip of the rubber comes over the tool and the locking strip. if you're right handed push the tool to the right with you're left hand,and at the same time push the locking strip into the tool and the rubber with you're right hand ,and keep it wet,I had my wife do the brushing as I went along it's not easy but once you get it started it goes better.My Wife also keep the long end of the locking strip feeding it into my right hand.
Pete
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Got a couple of dried out window rubbers that I need to replace in the near future Peter, gonna have to get you over for that exercise. Treat you to a burger afterward. Thanks for the description DG
Denny G Sandwich, IL
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I agree with everything Pete said except I'm left handed and it seemed easier for me to push the tool to the right with my left hand while feeding the locking strip in with my right hand. So if you're right handed I'd try the opposite direction, but do whatever feels right for you. I used a spritzer bottle with the dish soap, keep it wet! I managed to do it by myself while my wife was out shopping - what else is new? It's a learned art, it took several tries before I got the first rear quarter window done. If the tool slips out, (no comments please) I found it best just to pull out the strip and start over, I was never successful trying to continue on from that point. I thought the rear window was the easiest because the surface is pretty flat. The quarters are harder because of the compound curves, you have to continually watch the angle of the tool in relation to the surface. | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | In the tip section there is a post suggesting to use a paint can opener, so that's what I used (after throwing the bead tool across the garage several times out of frustration). The paint can opener worked like magic. I think I was about 20 minutes on each of the corner windows and slightly longer on the back. Plenty of soap and no help from my wife. (I did use her help to put the glass in). The paint can opener was free at the local home improvement center.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Jan 2011 Posts: 152 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 152 | Thank you very much, I can't get the tool to work either. I will try your suggestion.
