7 members (Donf, Gdads51, cmayna, Otto Skorzeny, Forty9, Gray_Ghost, 1 invisible), 91 guests, and 0 robots.
Topics128,118
Posts1,056,307
Members48,439
I just picked up an all original, chrome with 7-wire (cloth), self-cancelling 6V switch. Can anyone direct me to a wiring diagram that is complete? Thanks.
this tech tip should do ya
While this is great info. to have on hand, it does not match the wiring on the Guide 6004 switch I am looking at now. I am looking for a schematic that I can use w/o having to work through the troubleshooting.
some things do require working thru - try here for a schematic, but if your colors don't match what Cletis has in our tech tip ....
Yes--a test of patience. The flasher is 3-pronged. I am looking for someone to ride in on their white horse on this one!
Problem solved with schematic from 1951 Chevy Accessories Installation Manual. Took unit apart as cloth wiring color/markings hard to see and just followed the wiring pattern as pictured. Mission accomplished! Thanks everyone.
