| | | Forums66 Topics128,139 Posts1,056,459 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | The PO pulled the rusty bed floor angles off the bed sides with a pry-bar leaving dimples in the sheet metal at each spot weld. I've hammered on some of them trying to flatten them - this is not working. Don | | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | http://www.chevelles.com/forums/showthread.php?t=333455This might help Probably need to do some shrinking as well, as am guessing between you hammering on them and the other guy using a pry bar the metal is stretched...Eric | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | Eric,
Sorry! I've been gone. I really don't know anything about shinking, how is that done?
Don
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | If you have no experience with metal working, I would suggest buying this book. http://www.amazon.com/Key-To-Metal-Bumping-Book/dp/B002S4Y7RSThe book is almost 60 years old, but pretty much still on point. You might also consider buying a shrinking disc that has a video with it. | | |
