| | | Forums66 Topics128,018 Posts1,055,340 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 20 New Guy | | New Guy Joined: Feb 2011 Posts: 20 | Hi guys, I have a chance @ buying a complete front clip out of a '75 nova to put on my '48 half ton. Also, included in the deal is a 10 bolt rear end out of the same nova. All for $450.00. Will this clip fit on my truck? will the tires fit in the fenders? This is a big step and want to do it right. Thanks for any info you can give me. Keenan | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I have a 74 Nova clip under my 52 1/2 ton.I don't know if there is a difference in 75.The front wheels are Chev rally rims,7"wide 4" backspace.If I turn the wheels in a tight turn with two people in the cab the tires do rub on the fenders.Tires are 205R/65/15 The rear end is a 10 bolt out of the same Nova.Rims are Rally's 8" 41/2" backspace,tires 245R/60/15.The tires were real close to the box sides so a 1/2"spacer was used.Sorry I don't know the actual widths of the front or the rearends Hope this helps you Boyd | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Keenan- the '75 Nova is 2" wider than the '68-'74 Nova. It will work but it'll be tight with the wheels/tires in the front fender openings. I used a '79 Camaro clip (same as '75 Nova) and used 15x6 wheels with 4" backset. 205/75/15 tires. I also tweeked the fender openings a bit and have adequate tire clearance. I don't like the idea of using 1/2" spacers for the rear wheel clearance because of safety issues. (Some guys will argue that it is safe , but I don't agree.) I added mini wheel tubes in the bed so that the tires don't rub on the bed sides. (Camaro 10 bolt axle.) Basically you need 1.5"-2" of clearance and they'll never rub. | | |
