5 members (1955 1 Series, Gdads51, KEVINSKI, 2 invisible), 96 guests, and 2 robots.
Topics128,170
Posts1,057,033
Members48,458
Hey guys,
I need to know if your '60-'62 trucks have a hole in the front of the frame rail, behind the bumper, on the underside (side toward the ground) of the rail. This is in the area where a sway bar would mount.
My Suburban has matching holes on each side of the chassis, 10 inches back from the bottom edge of the front bumper. I just need to know if they all do.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
burbs and panels of all years had front [anti]sway bars
not all as my 64 4 x 4 panel did not come with one.
ron
My '61 didn't have one either.
And I've never seen a '60-66 truck in the junkyard, pick-up or panel, that had a factory front sway bar.
-Brad
Details here!
I have a factory swaybar in my 65 Brad. I could find a pic for ya'.
Yeah, I'd like to see one.
I've seen them on '67-up, but never the earlier ones.
-Brad
Details here!
do y'all have assembly manuals? should show in there if/what models had them, the 55-59's all do and the AD's I've seen have'em - they might have changed later ohwell
Neat. Thanks.
That one won't work on a '60-62 though, because of the way it mounts on the lower control arm.
Still looking for someone with a '60-'62 to see if that hole is in all the frames.
-Brad
Details here!
the only 60-66 truck/panel/burb I've ever seen with a factory sway bar was a 66 Custom Camper 20, also only thing assy manual shows as having one standard.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
My 61 3/4 ton has a set of 3/8 holes. I didn't measure, but it looks about 10 inches back
